Solid Wood Machining
holzher 1265 grid problem
7/5/14
kinsella
We have a 1265, and the grid got jammed on the rotating shelf supports.
Now the grid stays in the down position. I have reversed the air lines on the valve on the back of the saw. This makes the grid go back up.
However when you try to lock the saw in the horizontal pos. over the grid it will not shift. Vertical sawing is not affected.
I have tried to contact holzher on this, and I am met with, if you didnt buy from us, no help.
Any ideas are helpful. thank you.
7/7/14       #2: holzher 1265 grid problem ...
KenW
There is a roller limit switch on bottom left rear that can get knocked out of whack...has happened on ours....
7/7/14       #3: holzher 1265 grid problem ...
E Shaw
Try Lee Johnson @ 803-517-4131
