Solid Wood Machining
SCM T130NPS
7/13/14
Correy Smith
Website: http://matsukazewoodworking.com
Hey Guys. looking for some misc. small and not so small parts for a 2000~2002 era SCM T130NPS.
Hold Downs
Locking spacer with set screw to be used directly below lock nut
Table Rings, I have the largest two need at least the next size down. It would be approx. 8.25" in diameter with a .386~.39 thick lip. Seems to be same parts number as T110. But the T110 only shows three rings, T130 is five. I probably only need one or two more in the next sizes down.
I am also missing some of the " t nuts" for various set-ups with the tenoning plate that loads on the sliding table. I am sure I can Macguiver any of it from the hardware store but if I can find it I would lean toward OEM.
I also need a fence for the sliding table, flip stops etc.... OEM or other would work. Suggestions on after market very appreciated. Kinda like the SCM telescoping fence though.
There are also optional accessories in the manuals , none of which came with this particular machine but always interested in upgrading for ease of use.
Definitely going to look in to getting an Aigner fence, but would be quick to grab one used.
While I am on the soap box, I am also looking at large tenon discs and various cutter heads. Rebating and dual angle corrugated heads. If anyone has tooling for a 1.25" spindle that wants to sell I would be happy to hear what you have.
I am also thinking if I could find the 40mm spindle I would have more options on used tooling for cheaper than 1.25" tooling.
Thanks,Correy
