Solid Wood Machining
changing a Scmi 5 head moulder from 440v to 220v
7/18/14
Adrian Member
Anyone out there know how to switch my 1984 p170 5 head moulder from 440v to 220v? Its suppose to be dual voltage and all the motors do say both voltages. The problem is that I don't know how to switch it in the control panel box. It does look like it has a voltage transformer. Any help would be greatly appreciated.
7/21/14       #2: changing a Scmi 5 head moulder from ...
Adrian Member
Thanks for the response, where would I be able to get the breakers and wiring diagram for the control panel? Would it be easier for me to just by a transformer they told me a 75kva would do and I've found one at a good price.
7/21/14       #3: changing a Scmi 5 head moulder from ...
Mark Elliott Member
Adrian,
Go for the transformer, much less hassle.
Mark
7/30/14       #4: changing a Scmi 5 head moulder from ...
Rob
Changing from 460 to 230V will require the replacement of the breakers as well as changing the connections/jumpers at the motors. Also your machine may not be wired for the lower voltage so you may have to pull heavier gauge wire as well.
