Solid Wood Machining
change Scmi moulder from 440v to 220v
7/18/14
Adrian Member
I have a1984 Scmi 5 head moulder that I need to change from 440v to 220v. Any one know of how to change the wiring in the panel box from 440v to 220v .it does look like it had an internal voltage transformer. any input would greatly be appreciated
7/21/14       #2: change Scmi moulder from 440v to 22 ...
Russ
Website: https://www.mirror-reflections.com
First, lets start by stating this should only be done by a qualified factory rep. or an electrician that works with 3 phase. I have done many but I an not familiar with your machine but this may help you realize what needs to be done.
Every motor will have to be re configured (change the jumpers around) feed beam motor and speed motor as well.
Every circuit breaker will have to be changed out to the new size, transformer will have to change the jumper sequence.
Not something you would want to do by yourself unless you're comfortable around this type of operation. I would contact the manufacturing company for all the new breakers and a list of things that need to be accomplished with electrical cheat sheets to keep you from making an error.
Best of luck
7/21/14       #3: change Scmi moulder from 440v to 22 ...
JR Rutter Member
Like Russ said - You need to find and replace all of the motor overload breakers with double the amperage. Rewire the motor windings for lower voltage. Change the pins on the low voltage transformer.
7/21/14       #4: change Scmi moulder from 440v to 22 ...
David Egnoski  Member
Website: http://www.richmondcabinet.com
Consider a buck and boost transformer. I run a 440 volt CNC router from 208 volt 3 phase via a transformer. No problem.
7/31/14       #5: change Scmi moulder from 440v to 22 ...
Rob
Russ is right on
This is the best case scenario as in going from low to high voltage. But you are going from high to low. In this case it is a good bet that the factory has wired the machine for the higher voltage which means the wire size at all 3 phase motors will be too small and will have to be replaced with a heavier gauge wire. Better get your ducks in a row for this one- or buy a transformer.
8/26/14       #6: change Scmi moulder from 440v to 22 ...
Adrian Member
Russ,sorry for the delay on the response but everything has been checked out and changed to 220 . you mentioned that the jumper sequence would alsohave to be changed.? any help on that would be appreciated. again thanks all of those who responded it did help tremendously.
8/26/14       #7: change Scmi moulder from 440v to 22 ...
JR Rutter Member
Jumpers: The motors should have plates that show which winding leads need to be tied together and connected to power. These are inside the box where the power wires enter the motor.
