Solid Wood Machining
Finger joint cutter heads
10/10/14
Curmudgen Member
Can anyone help me to decode the following finger joint cutter head specs? We just bought a finger joint machine and I need spec out the cutters. I know everything means except the 11~3.7T number. The spec is 160-2T-11~3.7T-70 where 160 is the OD, 2T is the number of teeth, and 70 is the bore.
10/16/14       #3: Finger joint cutter heads ...
RT
Call AceCo.
www.aceco.com/
