Solid Wood Machining
Blades for sliding table saw
11/16/14
Correy Smith
Hi, if you were to only own two blades. one for ripping 1~2" hardwoods, and another to finish cross cut the same but would like to use for some sheet goods also ,what would you recommend? Specifically 12" but the saw has 16" capacity. 12" seems like it will cut 95% of all I do and looks to be the best for economy sake.
I don't intend to only have two blades of course, but will buy two to start and get doubles and others with different geometry and tooth spacing for other specific tasks as time goes forth.
Curious of how tooth spacing changes the cut when you go from a 24tooth 10" to a 12" 24T. or larger diameter.
Any thoughts on brand and use , all appreciated thanks.
11/17/14       #2: Blades for sliding table saw ...
We use:
Hardwood blade Leitz 58057 300 x 3,2 / 2,2 x 30 HW Z48/19,63 $109
Plywood (or cross cut)
leitz blade for altendorf wk 850-2-03 058206 350 x 3,2 / 2,2 $139
