Solid Wood Machining
Delta Shaper 43-379 Height Adjustment...
11/28/14
Dave Winters
Having a heck of a time loosening up the height adjustment on this machine. Very hard to turn the handwheel to adjust the height. How do I go about fixing this?
Thanks-
Dave
12/4/14       #2: Delta Shaper 43-379 Height Adjustme ...
Jesse Andreini Member
On my delta the height adjustment screw has an opening at the top where chips fall in and jam it up. Kind of a pain to clean them out, but if you look down through the arbor opening, you should be able to see the vertical threaded shaft and whether there are chips jammed in the top.
