Solid Wood Machining
Tear out on birch
12/16/14
Steve
I am using a lot of birch and am running the ends on my double end machine. The jump cope is doing a great job but the main will pull out a patch of fiber for no apparent reason. The area that is being pulled out has a normal grain pattern and the moisture content is fine. It does not seem to matter the type of cutter that is being used. We get the same results from HSS, carbide and diamond. The odd thing is that it is only happening on one side of the machine.
1/3/15       #2: Tear out on birch ...
Dr.David Rankin
Sounds like you may have one of these possible problems:
1. Tool may be to far away from the track.
2. If this is direct drive(no belt) you may have a bearing problem.
3. If belt driven; bad belt or de-laminated belt.
4. Dovetail which adjusts the spindle maybe loose or in need of cleaning.
5. Tooling still could be an issue. Dullness, wrong hook or grind angle, incorrect type of tool material, etc.
Be Safe,
Dr. David Rankin
