Solid Wood Machining
castor on plywood
12/18/14
nick Member
I am a cabinetmaker and I have 4 machines, 2400 pounds (bacci tenoner), 1050 pounds (bacci mortiser), and two at 650 pounds (pade borer, italian bandsaw).
I wanted to make all four machines mobile with suitably rated castors.
I wanted a varnished plywood floor as its
nicer to work on than the concrete slab below. But im thinking the
plywood and castor combination might not work too well over time......
Ive got a felder CF741 centrally located but the tenoner, mortiser and
doweler ill have to bring out as i need them. Hence the castors.
Has anybody delt with machines on castors on a plywood floor, concrete
slab below? Thoughts?
12/18/14       #2: castor on plywood ...
I would suggest a pallet jack to move the machinery around. A pivoting caster under that heavy of machine will dig a hole in the thin face veneer of plywood rather quickly.
12/19/14       #3: castor on plywood ...
Jr Lee  Member
Website: http://www.leeconsultants.info
Nick,
I agree with Rich. I have have a Globo borer, ~1500lb, on 6 or 8" castors and it is a bear to move. I have used a pallet jack to move heavy objects and it is easier with the PJ. The cost of a pallet jack(at harbor freight) isn't much more than the cost of the castors and it can move more than 1 machine since it isn't dedicated.
Good luck
Jr
12/19/14       #4: castor on plywood ...
Bruce H
If you already have a concrete floor don't screw it up trying to overlay it with plywood. Heavy machines are an issue at the very least. You will spend WAY more money than it is worth. Buy some rubber matts and put around each machine. Easy to move, easy to change your mind and cost way less.
