Solid Wood Machining
Scraps
12/31/14
shaner
Other people who run moulders for mouldings, what are you doing with all the waste rip offs from 1"-2-1/4" material??
When I get done ripping up my jobs I usually have a lot of rip off waste and it ranges from 1-1/4" up to 2-1/2" wide in usually 3-4 main woods I run often.
Sometimes I get jobs that come in to use some of that up but still usually have a lot sitting around and in some woods starting to accumulate a large amount of material which takes up a lot of space.
What are people using this material for??
How do I find a good way to make something that is profitable so it covers all labor to mill it as well as time to sort and store it??
Just looking for some suggestions on how to market this material so I can make some extra money but also get most value for saving it and throwing it in burn pile.
Thanks to everyone who has some advise. Best of luck to everyone in the new year!!
1/1/15       #2: Scraps ...
JB
Sit on it for awhile then throw it away, two days later you'll get an order!!
Seriously, that is the million dollar question. We looked in to running base shoe for large flooring distributor but they pay so little it wasn't feasible. Unless you can find a home for it or have the capacity to value engineer in to something else you will loose money every time you move it or work around it. For us just about anything 1-1/2" and under is waste in most woods (we have a use for narrow maple and a couple others). Cabinet shops are a good candidate for the wider rips to use in their face frames and door parts, just price it attractively since you already got paid for it.......right?
1/2/15       #3: Scraps ...
Steve
You might want to check out some of the picture frame dealers in your area. Unfinished frame material for the DIY people. I use to buy all the drop from an operation like yours and had them mould it into document frame stock.
1/2/15       #4: Scraps ...
shaner
Steve, that is a great idea. Those are the kind of things I want to be able to use that for and make some extra money if I can set up and sell it.
Just need to also find some other items like this that I can go around and market this material too make some extra with when I have some slower periods since I am saving this material.
Please post any other ideas, I appreciate the help!!
1/2/15       #5: Scraps ...
Russ
Website: http://www.mirror-reflections.com
Shaner
Things like base shoe, small cove moulding run with a splitter, double the production in half the time, slip tongue for flooring manufacturers, small glass stops for window manufactures, stops for door manufacturers, there is a wide range on companies who can utilize these types of mouldings for you to use your fall offs on.
Hope that helps
Russ
