Solid Wood Machining
A more heavy duty sander than a jet 22-44 for small parts production?
1/12/15
Jake
I've got a few of the jet/Performax 22-44 sanders that get used 6-8 hours a day in a production environment, sanding hardwood pieces that are 5/8' x 4" long x 1/4" thick.
My problem is the conveyor belt drive motor, I get about a year out of it before the gearbox self destructs. The motor/gearbox runs about 200 bucks. Is there a better solution? I've got a couple wide belt sanders, but that seems a bit overkill, and they're being used for other processes. Thanks!
1/17/15       #2: A more heavy duty sander than a jet ...
Rob
I have a Powermatic dual drum sander. As a furniture maker I don't use it on a production basis but it has served me well. It is much more robust than the performax style. You will also get more production as the feed is faster. It also shines when changing belts, its spring loaded design makes it very easy for one person to change the belts.
