Solid Wood Machining
T&G Shaper Cutter
1/16/15
Sean Member
There seems to be a conspiracy regarding tongue and groove shaper cutters for thick wood. I'm looking for a set of carbide cutters for at least 1 1/2" thick wood for a 3/4" spindle shaper. I don't really want to go to the insertable knife type heads. I can't imagine it's any kind of a safety issue, as you can get some pretty bulky moulding cutters that would take just as much of a bite. Does anyone have any input? I think I've looked at every manufacturer there is. Thanks for looking.
1/17/15       #3: T&G Shaper Cutter ...
D Brown
You may find the spindle size will be larger than 3/4" , so you use bushings or sleeves to make it fit your spindle correctly .
1/17/15       #4: T&G Shaper Cutter ...
3/4" spindle and 1-1/2" thick material is about the limit anyone would want to do. 1-1/4" spindle is more common.
Also, non-insert cutters will have to be a minimum of 4 piece cutter bodies with spacers, since the fit of the groove cutter will vary/reduce with future sharpenings. This will increase your costs right at the start.
Insert tools would only need two or even one cutter body.
If you asked me, I would suggest insert with 1-1/4" bore and bushings to go to 3/4". I don't think I'm part of a conspiracy, but that doesn't mean there isn't one.
1/17/15       #5: T&G Shaper Cutter ...
Rob
I would agree a 1/4" bore bushed to 3/4 insert cutter would be best. Furthermore you never know, you may get a larger shaper in the future so you can still use your expensive tool.
Another alternative is a small corrugated shaper head available in 3/4" bore and have the knives ground and maintained, Russ Rego at Mirror Reflections could probably help you with that.
https://www.mirror-reflections.com
Charles Schmidt has the heads
http://www.cggschmidt.com/cat1100/index.html#/32/
1/17/15       #6: T&G Shaper Cutter ...
Russ
Website: http://www.mirror-reflections.com
Sean We have many styles available for 1-1/2" thickness, it would require a set of two knives for the tongue and a set of two knives for the groove. What type of wood will you be milling, it may not require carbide which would reduce the cost substantially. I have included a link below to the page with all the 1-1/2" tongue and groove profiles we have in stock, if you don't see what you need, feel free to contact me, we can make them custom if you wish. Rob...thanks, as always, for the mention
Link
1/17/15       #7: T&G Shaper Cutter ...
Russ
Sean I may have placed the wrong link below, lets try this one. If it fails to work, try this Input 1.500" in both search fields, that should take you to the correct page to view the profiles we have at 1-1/2" thickness.
Link
1/20/15       #8: T&G Shaper Cutter ...
Sean Member
Thanks for the responses. I'm studying the insert knives and heads, looks like the way to go.
Sean
