Solid Wood Machining
Machining Curved Handrail
1/22/15
Jebaroo
We have a 6 head moulder
We have a Mikron moulder.
We have the ability to make arched and curved mouldings.
But I now need to make a 2" round handrail (or foot rail in this case) on a 8' radius. We will have no problem making the radius'ed blank for this, but I'm uncertain on how to get it into a moulded into a 2" handrail.
Any help??
Thanks,
1/22/15       #2: Machining Curved Handrail ...
Russ
Website: http://www.mirror-reflections
Jeb
What about milling 1/4 of the round at a time like you do when you make a full round on your moulder?
Take 1/4 of the 1" radius and add 1/32" or more blend area to it, grind the moulding knives and make four passes.
Just a though, it may be more complicated that that, I have a downloadable full round at that size on our website.
1/23/15       #3: Machining Curved Handrail ...
Josh Koschak Member
Why is this treated different than an arched molding with a half circle profile?
I would glue up two blanks; a top half, and a bottom half. Run the blanks, flip one and glue them together, with an accurate glue a little bit and sanding, voila.
Trying to do this out of one blank would have a lot of set up time for running the second side as it wont be riding on square edge.
Let us know how you proceed.
1/26/15       #4: Machining Curved Handrail ...
SG
I did this on a much tighter radius a few years back simply using a 1" radius bearing bit on a router table. An unsophisticated approach, I know, but it worked fairly well. Required a bit of handwork to make perfect, but the result was good and set-up quick and easy.
1/31/15       #5: Machining Curved Handrail ...
Harry DeVrieze
Laminate curved blank. 1/4 knife on shaper.
