Solid Wood Machining
Dial indicator
2/11/15
I need to replace the blades on my powermatic jointer and planer. Whos dial indicator do you recommend and why? Any links?
Thx
2/12/15       #2: Dial indicator ...
JeffD
I bought an inexpensive one out of the MSC catalog. Don't need anything better since I'm not a machinist.
FWIW I don't use it for setting jointer knives. Been using the stick method for years and figure if it works don't fix it….plus it doesn't require any expensive tools:)
good luck,
JeffD
2/13/15       #3: Dial indicator ...
Chuck Rankin
Hi Mike:
Here's some information on a few of the knife setting jigs we offer. The image is a Mag-Set planer & jointer knife setting jig. One set can handle a knife up to 20" in length.
best regards,
Chuck Rankin
Wood Tech Enterprises, Inc.
P.O. Box 2226
Fairview, NC 28730 USA
Phone: 828-628-4414
Fax: 828-628-4490
View larger image
Mag-Set knife setting jig from Wood Tech
