Solid Wood Machining
Am i being too picky
2/25/15
I just set my new jointer knives last night. When the boards are laying flat edge to edge there's visually no gap, but when i hold it up to the light, i can see the light. I know when i suck it in with glue, it will be perfect. Could i be litterly a thousandths or a half of a thousandths or half of a thousandths off on my cutters that i set with a dial indicator. Im sure the wood will expand or contract that much over night, but are others as super anal as im trying to be?
3/3/15       #2: Am i being too picky ...
Jay White
Need to leave some place for the glue.lol. made a lot of door panels off our ripsaw. Never any problems. Norm ruined a lot of people jointing those boards perfectly.
3/3/15       #3: Am i being too picky ...
I kinda miss his show
3/4/15       #4: Am i being too picky ...
Is the light in the center of the boards, or the ends? If the center, that's perfect. It's called a sprung joint and it helps limit joint cracking at the ends with moisture changes.
3/4/15       #5: Am i being too picky ...
Yes, its in the middle. The first few inchesa are solidly tight
I guess the 65.00 i paid for dial indicators were well worth the money
3/13/15       #6: Am i being too picky ...
Raul Member
The question of whether a gap ( in the middle) of the two boards is not so simple as a "spring joint" (which I don't use).
For example if the boards are a few feet long and only a few inches wide that gap will not be a problem. But if the boards are short and much wider and you can't close the gap by hand, then it's different.
Glue is a polymer and experiences cold creep. It moves under pressure. Maybe not fast, but move it does. If the gap can only be closed with clamps then odds are the tension will always be trying to pull the joint apart. It may succeed and that depends on all sorts of things.
