Solid Wood Machining
Bandsaw power feed
3/25/15
Kevin Jenness
Website: http://birdseyebuilding.com
We do quite a bit of resawing of 1/8" veneer for custom doors on our 20" 5 hp Aggazani bandsaw, feeding by hand. We are considering putting a powerfeed on it to make the cuts more consistent and cut down on passes through the wide belt. Any advice on particular make/models, abrasive covered versus serrated rollers for our application, anything else pertinent?
3/26/15       #2: Bandsaw power feed ...
Joe Doherty
Kevin,
I Set up a Felder FB600 24" bandsaw with a feeder and it works well. I think Comatic is one of the few companies making Power feeders. I have the AF19 but if I could do it over again I would get the pneumatic version. I use my bandsaw to rip and it is awkward to hold a wide long board and reach forward to move the power feeder over to start feeding the board. The pneumatic version opens and begins feeding by itself.
I use a Lennox Trimaster 3 2, 1" wide blade. The blade makes a lot of difference. I get very straight very smooth cuts.
My feeder has serrated rollers and I have not found any reason to want anything else. I have not noticed and marks in the wood from the rollers but I work with mostly hardwood and plane after reassign or use a sander.
I bought the AF19 with a 3 phase motor and added a VFD from Automation direct for variable speed control.
We split 5, 6" to 8" wide x 10' long 4/4 rough Sapele boards today and it took about 10 minutes with nice smooth results.
You will love the power feeder if you are doing this a lot.
Joe in New Orleans
4/11/15       #3: Bandsaw power feed ...
David Sipos Member
Website: http://minkawoodwork.com
have been looking into this matter and my finding are:
- you may need a larger than a 20" bandsaw to use the cosmetic feeder AF19.
Co-matic is almost the only one out there manufacturing feeders, Laguna, Grizzly all paint their colors on it but it is all made in Taiwan.
