Solid Wood Machining
Best Drill Press Recomendations
4/28/15
jim Member
Hello,
Looking for a new drill press to fit into an educational environment. The less bells and whistles- the better. Rack and Pinion lift preferable.
Can anybody give some recommendations.
Thanks,
Jim
5/30/18       #3: Best Drill Press Recomendations ...
Jon Walter
If what you’re looking for is a benchtop drill press that is capable of drilling both on wood and metal, this is a versatile option to consider. Featuring various types of speed and a high voltage 3/4 HP motor, Shop Fox W1668 ¾-HP 13-Inch Bench-Top Drill Press Spindle Sander is a real performer as an effective and efficient automatic drill press. Drill press
Link
3/5/20       #4: Best Drill Press Recomendations ...
James Member
I think WEN 4214 is exactly what you need. This tool is extremely versatile, that’s why I bought it. It has a lasor, which you can adjust however you want. It helps you to work really quick, especially when you have a bunch of drills. This tool does a great job and I’m really pleased with it.
