Solid Wood Machining
Bat Ear Relief - 8" Dado Set Recommendation
6/30/15
Paul
My current dado sets have served me well, plowing grooves where smooth bottoms and bat ear marks were of little concern. Now I need more precision in the cuts. Can I hear recommendations on 8” sets that actually produce smooth side and bottom grooves without the ear marks. Is this a condition best solved with a dollar “investment”? Thanks in advance.
7/1/15       #2: Bat Ear Relief - 8" Dado Set R ...
I assume you want clean cuts in solid stock. I have found that the quality of cut was determined by the competence of the sharpening service more so than the blade manufacturer within reason. Buy a quality industrial set intended for solid wood and have it sharpened by the best shop in your area. My sharpener asked how I wanted the Dado setup, with the outer plate. 010" higher than the chippers or dead on. I have found that the money I have spent on good sharpening ($2/blade more) has paid of in longer life and better finish. If you are dadoing daily then consider two sets so you don't have down time when sharpening.
But to answer your question directly, I have an 8" set by FS Tools.
