Solid Wood Machining
strip easy forms
7/4/15
doug keith Member
Hi. I am wondering if anyone has any ideas about a better (faster) way to cut those 1/4" x 1 1/4" holes in the 3/4" form plywood for the strip easy ties to pass through. I typically use a router with a plunge bit but I find it slow and tedious. Any new tools out there that will plunge or cut a small narrow hole?
Cheers
7/11/15       #2: strip easy forms ...
Kevin Jenness
You can get close to those dimensions with a Festool Domino. A 6mm bit at the widest setting gives a 29mm wide slot, while an 8mm bit will produce a 31mm wide slot. Not sure if that is close enough for your purposes, but certainly would be faster than a handheld router. For quantity production sub it out to a CNC operation.
