Solid Wood Machining
Rip saws
7/6/15
Marion Gee Member
Looking to buy a used SL Rip Saw but never used one. Can the blade be adjusted to an 8 degree angle to rip 5/4 for casing?
7/6/15       #3: Rip saws ...
Mark Elliott Member
Marion,
I have never heard of a SLR that had an arbor that tilted for rips.
I think most shops do those rips on a bandsaw.
Hope this helps.
Mark
7/6/15       #4: Rip saws ...
marion gee Member
Thanks Mark, I appreciate the response. I was looking at an Oliver Resaw bandsaw but I didn't know if a bandsaw would be quick enough
7/7/15       #5: Rip saws ...
Mark Elliott Member
Marion,
It will only be quick enough to re-saw 5/4 into 2 blanks for a casing, not for straight lining.
Mark
7/9/15       #6: Rip saws ...
I once had a shop that had a straight line saw for making good blanks for the molder, and several patterns were ripped from 6/4 and then sent thru a Wadkin PBR resaw on an angle for making casings. The saw had a 20 hp motor, a good power feeder, tilt table, 3" wide blades, and would easily process 3" wide Poplar at 30 feet per minute all day.
Trying to resaw on a straightline saw would never be recommended.
9/11/15       #7: Rip saws ...
William Falberg Member
Website: http:/www./falbergsaws.com
I've been working on an all-purpose 2HP micro-mill veneer resaw for five years now and got to this point with it. It needs a wider more aggressive 1" blade for these rip cuts but since I recorded this I've added a log clamping system that allows for whatever angle you want without stacking wood scraps behind it and holding it down by hand.
