Solid Wood Machining
weinig quattromat 22
7/15/15
jerry Member
HELP
my friend has just moved to a new shop. The machine works fine on top and bottom cutter.
However the back cutter operation is faulty and is kicking the timber out on the feed fence as it goes through. If you run the timber through on o ie no cut it runs through fine.
Have lined the fences through
checked feed wheels
everything is level
new blades
side pressure calibrated
and it still does it. I am no expert but really want to help my friend get up and running properly any help would be appreciated
thanks Jerry
7/15/15       #2: weinig quattromat 22 ...
Russ
Website: http://www.mirror-reflections.com
Try checking the alignment of the rebate cutter. I have attached an article to help you better understand the way it is aligned. I hope this helps Russ
Mirror Reflections link
7/16/15       #3: weinig quattromat 22 ...
jerryo Member
Unfortunately This machine doesn't have a rebate attachment. Just a fixed fence and a feed fence.
thanks Jerry
7/17/15       #4: weinig quattromat 22 ...
Russ
I would call Weinig, In my recollection the quattromat should have a rebate cutter on it, maybe it was removed and this is the cause for your issues. You can easily tell if it had one installed at one time. look for the Pin holes that secures the rebate cutter guide fence drilled into the bed of the machine, maybe older models did not have this I am not so sure on the 22, but the 23 had rebate cutters, as you can plainly see in this pdf also referred to as a reference engraver in the wording
I hope this helps
Russ
file:///I:/Users/RussR/Downloads/pdf-wei_quattromat_23p_en_ca2002.pdf
7/17/15       #5: weinig quattromat 22 ...
jerry Member
Hello all problem solved. Thank you so much for the replies and the e mails as well.
Rang weinig and various specialists but to of no avail.
The problem was so simple in fact almost obvious. The machine was moved via a crane so we assumed it had received a knock of some description so after setting up every possible adjustment from the beginning fence, new blades etc all it was that was causing the "kicking out" was the back side cutter needed adjusting above the fixed fence by .2mm and hey presto ran like a new one timber cutting correctly. Something I will neverforgetin a hurry.
Thanks again
