Solid Wood Machining
Adjusting tables on an scmi f 410
8/17/15
Kevin Member
Just picked up a 1997 F-410 and need to adjust the tables. No info in the downloadable manuals. Can anyone offer any help? SCMI wants $250 to tell me how to do it. Thanks,
Kevin
9/19/15       #2: Adjusting tables on an scmi f 410 ...
Chris Hall Member
Hah! Gotta love that new policy from SCM North America.
I have a 1999 SCM planer and I used to call SCM tech support with questions (before they institute the fees), and they gave me wrong info almost every time. The problem is that there is no one in the tech department there who was with the company in the 1990's and thus their actual familiarity with machines from that time is rather limited.
What sort of adjustments are you looking to make? What is happening when you are jointing? The board will tell you everything you need to know about the table alignments.
A jointer is a very basic machine with fairly straightforward systems for raise/lower and adjusting tables in co-planarity. That said, not sure if those machines have fully adjustable tables or not.
