Solid Wood Machining
Gang ripsaw outfeed chain
10/5/15
David Waldmann  Member
Website: vermonthardwoods.com
We want to put in something more than a simple table on our outfeed to help speed up the process. We'd like some sort of chain that will get the stuff out of the way of the next piece, as well as ferry the edgings to our horizontal grinder.
I've been looking all over the internet, and have only found one purpose-built solution. It uses sensors and only moves when a board has finished exiting the saw. I like the idea, as there is no chance of the motion disturbing the straightness of cut. Further, it would allow a single person to rip until the chain is full, and then go sort the material.
However, the one I found seems almost ridiculously expensive (hear $40k). Or maybe I just don't realize how expensive it is to build such a device? It's almost as much as our Raimann saw...
BTW, we do usually try and have a tailer on the saw, so if a "traditional" chain is a viable option I'd like to hear about that as well. We mostly are ripping 12' and shorter, but do up to 16' several times a month.
http://www.woodstorm.com/ddx.htm
10/7/15       #2: Gang ripsaw outfeed chain ...
Ever see a Tailboy?
Tailboy
10/7/15       #3: Gang ripsaw outfeed chain ...
I haven't seen that particular item, although I've seen various return feed type systems. The first one that I saw at another business was a Doucet. However, I'm looking for something that is designed for a dedicated tailer, and if it could also serve a one-person operation that would be a bonus.
Doucet rip saw return
10/13/15       #4: Gang ripsaw outfeed chain ...
mj  Member
We disassembled our gang a few years ago in favor of a smaller system. However the MJ saw consisted of a set of pinch rollers at the rear of the machine that turned at a much faster speed then the chain so essentially supporting, then spitting the material on to a cross conveyor. We fed into a chop line so the operator dropped the edgings onto a conveyor which fed directly into the hog. It was a large setup but could really chew through the material. I might still have pictures.
