Solid Wood Machining
Weinig Rondamat - ok to use plastic templates?
10/28/15
scott Member
Is it possible to use plastic / plexiglass templates for grinding Weinig molder knives on a Rondamat? We could cut the templates on our CNC router which would be convenient.
10/28/15       #2: Weinig Rondamat - ok to use plastic ...
shawn
Website: http://activetooling.com
NO PROBLEM grind away!
10/28/15       #3: Weinig Rondamat - ok to use plastic ...
Jay
Plastic templates are pretty much standard nowadays. I started out with metal template stock, scribe, hacksaw, bench grinder and needle files.
Now you can get a plastic one done on a cnc for about $30.00.
You don't need much pressure against your tracing pin while grinding.
10/30/15       #4: Weinig Rondamat - ok to use plastic ...
Russ
Website: http://www.mr-moulding-knives.com
Look for a cast acrylic plastic it will have longer wear properties.
Our profile catalog has over 15,000 template ready designs that can save you hours of design time.
All the best
Russ
