Solid Wood Machining
Flooring with Circle Saw Milling Marks
11/17/15
Joe Member
Hi there! We make custom hardwood flooring (up to eight inches wide), and have been asked to make oak flooring that will have as much of the circle milling marks on the face of the flooring as possible.
Has anyone done that? We would love to hear folks thoughts on how they are doing this.
Our standard way of milling our flooring is to rip and hit-or-miss plane to size. And then run the flooring face down thru the moulder, stress relief being done by the top head. Would this work for the circle sawn face? We worry about side match problems.
Thanks!
11/17/15       #2: Flooring with Circle Saw Milling Ma ...
Bruce H
Here is something to start with.
Look Here
11/17/15       #3: Flooring with Circle Saw Milling Ma ...
Jason
Circular sawn flooring is pretty much a hit or miss floor so side match..there will be a step that comes and goes throughout the length of the board.
You said you hit or miss the lumber first so it shouldn't be taller than your side heads which is good.
What we do is "hit" the one side through the planer and then run the rough side face down through the moulder. Table on 1/2 or less and I replace the .020" shim under the last bed plate with a .005".
You can still adjust how much circular marks that you want with the adjustment of your infeed table.
11/19/15       #4: Flooring with Circle Saw Milling Ma ...
red oaks lumber
we built a machine to reproduce accurate(authentic) saw marks. to date have made over 100,000 sq.ft. sorry i won't give any details
12/10/15       #5: Flooring with Circle Saw Milling Ma ...
Gene Wengert-WoodDoc
I saw this done once: The original flooring pieces were double thickness. This blank was run through a flooring machine to put two tongues and two grooves on the edges and both faces were milled smooth with a typical flooring groove(s) on both faces. At this point the thickness of the blank is well controlled. Then the piece is sent through a resaw and cut into two equal thickness pieces. This gives the rough surface with saw marks.
I also saw a variation of this making paneling. This provided a rough side and a smooth side for the paneling--consumer option on which side was out or exposed.
12/21/15       #6: Flooring with Circle Saw Milling Ma ...
Alex Member
Website: http://finishingtouchcarpentry.com
Hi
As Bruce mentioned above the "Frankensaw" we built can handle up to 18" wide planks. If your in the Reno/Tahoe area
happy to run them for you.
Alex G
Finishing Touch Carpentry
