Solid Wood Machining
profile grinder
2/10/16
doug mclaren  Member
i have my knives outsourced but would like to be able to sharpen in house. has anyone had much experiencewith viel af5. the size and cost seem to fit my needs? thanks
2/10/16       #2: profile grinder ...
Dustin Orth Member
I have had a Veil for 15 years or so. Good little machine but I now outsource all my profiles or sharpening. Takes too long on the veil and it's a dry grinder with no variable speed for the grinding wheel. I stuck mine in a slop sink wash tub and added a pond pump for recirculating a grinder coolant. Works ok, but no where near as good as the big boy grinders. You might be able to find a used heavy grinder for a little more money. Just my experience. Some day I'll buy a Weinig or similar. Till then I'll outsource.
2/11/16       #3: profile grinder ...
doug mclaren  Member
want to sell it? the down time sending out hurts,especially in middle of run. also nice to grind in head and mount. seems like it would take just as long to mount? again i only want to put fresh edge not grind a knife
2/11/16       #4: profile grinder ...
Dustin orth Member
Should try and find someone close to you that has one, unless you're in Colorado then you could see mine. It's not a bad little grinder just entry level for running big knives and may not give you the finish quality you may be expecting. Let me see if I can post some pics of the grind quality for you.
2/16/16       #5: profile grinder ...
Allie Trice  Member
Hey Doug...
I see the AF-5 cost twice as much now as when I bought mine. Just ran some radius and straight casing with knives made with the Viel so I shot some images.
View higher quality, full size image (475 X 505)
View higher quality, full size image (904 X 471)
View higher quality, full size image (750 X 563)
2/16/16       #6: profile grinder ...
doug mclaren  Member
impressive, i wouldn t even show my customers that profile. way to complicated. most of my 100 plus knives are much simpler. again , do you feel af5 capable of sharpening ? assuming you do?
2/16/16       #7: profile grinder ...
Allie Trice  Member
Doug:
If you have the template for the knife it would be real easy to sharpen one. I have to match what the contractors use around here(Alabama), which is about eight different casing profiles. My work is generally making the radius trim/jamb for the doors and widows.
2/16/16       #8: profile grinder ...
doug mclaren  Member
allie what machine are you running those knives in? are you going right from grind in head to machine? thanks
2/16/16       #9: profile grinder ...
Allie Trice  Member
Doug:
It's a Woodmaster 718. This is kind of a long story but here goes. I bought a Woodmaster S2 C/head which is a 8" long, two slot corrugated head. I cut it into to make two 4" heads. Use one of these in the grinder all the time and the other one in the Woodmaster. I use a dial gauge to set the knives radially. I have several C/heads I bought from Viel that work with the Woodmaster's 3/8" keyway but don't use them much because they are 3 slot heads.
2/16/16       #10: profile grinder ...
doug mclaren  Member
