Solid Wood Machining
Best angle for grinding moulder knives
2/24/16
Dok johnson
I mould red oak, so I already have the knives set in the 15 degree slots in the cutting heads, but I don't know what angle to set the profile grinder to. The guy before me carved every head at a different angle, is there a single correct angle?
2/26/16       #2: Best angle for grinding moulder kni ...
Keith Newton
Dok, for the most thorough answer, you should look in the knowledge base. Just type in molder grinding angles in the little windows up in the top right corner of this page.
Then, you can find more than you ever knew to ask about in the grinding manual of Charles G.G. Schmidt & Company.
I'm not sure what page, but it should give a chart for every wood species you are likely to need, with best sharpness, cutting angles, knife cuts per inch etc.
2/27/16       #3: Best angle for grinding moulder kni ...
Russ
Website: http://www.mr-moulding-knives.com
Dok I written a few brief but helpful articles on this subject I have attached below, hopefully it helps you. All the best Russ
Moulding Knife Grinding Procedures
6/28/18       #4: Best angle for grinding moulder kni ...
Jag
What is the best knife angle for moulding dense tropical hardwoods like Ipe, Greenheart and Purpleheart?
