Solid Wood Machining
Larick profile sanders
3/2/16
Dan Cook
Trying to get the info from actual users. Are these type of profile sanders worth it for sanding raised panels and edge profiles. If so, are there any on the used market. What brands are best?
3/2/16       #2: Larick profile sanders ...
Bruce H
I think you would find Vorwood's Turbosand system to work better. The only issue is your cutters and the sanding profile need to match.
3/2/16       #3: Larick profile sanders ...
Tim G
Works best on raised panels, I have one dedicated to that.
3/2/16       #4: Larick profile sanders ...
JimHerron
I have the Larick. Really, really like it for raised panels, not so much on edges. I have three heads to match my Freeborn cutters.
FWIW most doors I've done the last few years are square eased edge.
3/5/16       #5: Larick profile sanders ...
door shop guy
I thought about a profile sander in the past but decided against it for several reasons.
I think they only do good on the most basic profile. Any detail and it will distort the profile detail.
It is easy enough to use a Soft Sander pad and do by hand.
I have 16 raised panel profiles and over 40 outside edge profiles and there is no way i would spend outrageous money for custom heads when it can be done by hand very quickly and a lot more accurately.
Im just a one man shop but if i was a bigger shop i would probably have one for the simple profiles.
3/21/16       #6: Larick profile sanders ...
Jeff M
I have the Turbosand heads and Larick. I prefer the Larick for the profile I have, it is just a simple ogee edge. The Turbosand is an eased square edge. The paper is a lot more durable on the Larick. I don't think it would work too well on a tight radius though. Larry at Larick machine was very helpful with getting me what I needed.
7/22/16       #7: Larick profile sanders ...
Turbosand Guy Member
Website: http://www.turbosand.com
Try Us.
The Larick solution works well for very simple, soft, shapes. Profiles with sharp inside/outside corners, complicated bends, not so well...
The die-formed Turbosand inserts won't round-off corners and get into inside details as small as a .032" radius. Send us a drawing of your profile - we'll tell you everything you want to know.
Issues with life most frequently come from poor shaper/sander match or a tendency by inexperienced users to sand way to hard. Turbosand users can call us anytime to discuss these issues and troubleshoot; and if the sanders are faulty, we do warranty them and replace them when they are defective.
