Solid Wood Machining
Wood grinder chip sizes
3/7/16
David Waldmann  Member
Website: vermonthardwoods.com
Hello,
We installed a Weima Beaver 400 about a year ago. When first installed we had a lot of trouble getting material through it, and it turned out that the screen was too small.
So we put a larger screen in (15/20). However, then we started getting these long, stringy "chips", up to 8 or more inches long, and that caused blockages in our dust collection. The solution was to weld "baffles" on the back of the screen - that was supposed to keep the long pieces inside the cutting area so they'd get pulled back in and cut smaller.
It sure helped, but were still getting pieces longer than it seemed we should - lots of 3-5" pieces.
Recently we have been running a lot of hickory and it has been causing real problems. We've been getting chips over a foot long!
I have two questions:
1. Why are there "strings" in the first place? It seems from looking at the design that there shouldn't be anything more than an inch or so - it's "slow speed", but even at that it seems like the chip length shouldn't be more than the depth of cut (top of knife to bottom of knife) which is probably about 1-1/2", because the teeth are about 1" square, installed on a 45° angle. It seems like the incoming piece would be limited as to how far it can proceed by the depth of the "chip pocket".
2. If this type of "chip" is normal, how do we reduce it? Not only is it a real hassle to stop and unclog the pipe, but I can't imagine how it's accelerating wear on our airlock vanes. In fact, I can hardly believe we haven't had any issues with bridging in our cyclone now that I think about it.
For reference, the boards in the picture are about 8" wide.
View larger image
Official Weima product page
3/11/16       #2: Wood grinder chip sizes ...
We have greatly improved the situation by turning the teeth to fresh edges, and adjusting the counter knife to within spec.
We're still getting a lot of 3-4" long pieces, which remains a mystery to me, but it's a whole lot better than it was. At least it's functional.
