Solid Wood Machining
Building room doors- cope or stick first?
4/4/16
Dan Member
I'm trying my first set of room doors, and getting my shaper setups figured out. This may seem like a basic question, but do you prefer to run the sticking first, or the copes first? I've heard opinions both ways. When I run the sticking, I get a little snipe at the end. I know what causes it, and could get rid of it, but its a pain. If I run the sticking first, I can just cut it off. But then there could be blowout on the cope cut. On the other hand, if I run the coping first, any blowout will be cut off in the sticking cut. But then I have to get rid of the snipe. Blowout on the cope might be handled with a backer. Not sure the best way to go, and I anticipate doing a lot more of this, so I am using this project to get my methods down.
4/4/16       #2: Building room doors- cope or stick ...
Kevin Jenness
Sticking first is faster (fewer pieces to handle) and avoids running the sticking on short pieces which can be harder to feed. I often cope first so any blowout is removed with the sticking process, but you can get an acceptable result by sticking first with sharp knives and a well fit backer, especially if the backer is advanced every time to get a fresh surface behind the cope cut. To eliminate sniping, try using an outside fence.
4/6/16       #3: Building room doors- cope or stick ...
Copes first. This eliminates the need for back-up strips that may allow some blow out in a finished cut.
If you are getting a sticking snipe on your shaper, then your set-up needs to be adjusted. If you are taking a full cut off the face for sticking, then the fences need to be accurately offset and set in relation to the cut or you will get either snipe or run-out.
