Solid Wood Machining
RE: Grizzly Drum Sander-- Rollers
5/27/16
Tommy
We recently purchased a used Grizzly G1079 Drum Sander.
When researching how a sanding belt is installed on this sander, we found that a 45-degree cut has to be made on a 5-inch sanding roll, and repeatedly rolled on to cover the entire 24-inch wide roller.
I was wondering if there is any other alternative to this method. Are there any 24-inch wide sanding belts that we could be directly installed, instead of going through this process every time we want to change the grit on the rollers?
5/31/16       #2: RE: Grizzly Drum Sander-- Rollers ...
Spicolli
I use 6" hook and loop paper and can change grits pretty quickly. If your drum is not velcro wrapped, I would suggest switching. I would also recommend investing in good paper such as Mirka which will last longer without tearing.
