Solid Wood Machining
Which 26"-32" Thickness Planer for various kind of woods
7/15/16
cct Member
Hi all, I am asking your expert experience:
Please recommend a low cost, easy to use heavy duty planer for me. ;)
I need
a) 3-4mm cut in a single pass
b) as high speed as possible
c) Traditional planer blade
d) Heavy duty, can plane at least 10 ton of hardwood in a single day without stop.
e) Super easy to install blade.
f) Hardwood with different moisture content
ty
7/18/16       #2: Which 26"-32" Thickness P ...
tcc
Thickness planer? Isn't the wood already thick? Do you want to make it thinner? You need a thinness planer.
If one is a ton, would not ten be "tons"? I ask because I want to understand why you don't just buy a planer and start running it.
As for a magical machine that will never break down - buy Chinese.
7/19/16       #3: Which 26"-32" Thickness P ...
cct Member
Dear experts,
I mean i need to plane 10 X 1000kgs of wood everyday.
Which 26" heavy planer is recommended. One side is enough. 15HP minimum for traditional blade.
Thanks very much.
7/19/16       #4: Which 26"-32" Thickness P ...
cct Member
Dear tcc,
I already bought a china made planer, it break down (component burnt but easy to replace) almost everyday.. ;|. I need to give the machine a few breaks throughout the day...
But I still prefer china made or taiwan made planer because they are a few times cheaper. Please recommend a good machines for me.
7/19/16       #5: Which 26"-32" Thickness P ...
Bill Braskey Member
If you have a way to move 10 ton of lumber get a USA made planer that weighs at least 3 ton...
7/20/16       #6: Which 26"-32" Thickness P ...
ctc
Get a kraut machine - they are able to process wood using the metric system.
If that doesn't work out, try building your own.
7/20/16       #7: Which 26"-32" Thickness P ...
bb4
All this and, "low cost" to boot?
7/21/16       #8: Which 26"-32" Thickness P ...
cct Member
Dear experts,
Our stock is different from the stock in Europe. Our stock soak in water for long term and form very hard "skin". 1 ton or 1000 kg, only contains about 80 or less pieces of 8" X 7' stock or even less for stock that is 15". 10 Tons or 10, 000kg of stock only has 80 X 10 = 800 pieces of 8" X 7'. If a heavy duty can't perform the job, then the machine should not called as "heavy" duty.
7/21/16       #9: Which 26"-32" Thickness P ...
cct Member
7 Feet is about 2m. Heavy duty planer can plan around 9m/minutes. That means 1 minute can plan about 4 pieces.
1 Ton or 1000 kg, or 80 pieces of stock, only needs 80/4 = 20 minutes.
10 Ton or 10,000kg, 20 X 10 = 200 minutes or 200/60 = about 3 hours.
Reasonable? Most european stock looks extremely lightweight in youtube.
7/21/16       #10: Which 26"-32" Thickness P ...
Kilgore Trout Member
Your math is OK, but that is only one pass thru the machine. If you are going from rough sawn to finish, each side may get 2-3 passes thru the planer.
If 2 passes per side, multiply your numbers by 4.
What are you doing with the lumber after planing?
Heavy duty is a subjective term, not a defined term. China is not known for accuracy in their machinery descriptions. One man's heavy duty is another man's lightweight. Good used equipment is available easily in the US, but I do not know where you are.
7/22/16       #11: Which 26"-32" Thickness P ...
None of my business, but why is he planing lumber at the source? Generally, logs are hauled to a sawmill, and sawn, then taken to a collection point where they are put on stickers to partially air dry (PAD), then moved to transport for export, or dried in a kiln, then exported. Planing does not happen until the wholesaler or retailer does it, if then.
7/26/16       #13: Which 26"-32" Thickness P ...
cct Member
cutterhead diameter 98mm
cuttinf circle 101mm
what ia the maximum planing depth?
ty
