Solid Wood Machining
weinig end snipe
7/30/16
Bennet Member
I am running 1x6 WRC T&G pattern with a 3/8s edge bead on the tongue side. I am running the tongue on the left side head. My issue is that many of the boards have 3-4" of snipe on the tongue side. my outfeed table has a track to keep the boards somewhat controlled. it seems like the back end is sliding towards the outside head anywhere from 1/4-1/2". We did not blank out the material it is straight from the mill and does have a slight variation +- 1/8. should i expect to be able to run with no snipe on the end or is it my setup?
7/30/16       #2: weinig end snipe ...
Jason
If your running rough stock sometimes the wood can be thicker than your right side groove cutter is tall. The fence will peal away to an extent but if it's too much it will push the board to the left and cause taper or snipe. I hate running material that has not been blanked out.
7/31/16       #3: weinig end snipe ...
Russ
Website: http://www.mr-moulding-knives.com
Bennet Check and see if your pressure shoe is is out of parallel in both directions front and back and side to side. Also take radial readings from both ends of the knives they should be within a thousandth of an inch or so. Place a straightedge across the bed plates to see if they a parallel ( a flashlight or feeler gauges will work well. I have attached a link on how to parallel your pressure shoe, I hope it helps you find the issue, sniping is never good. All the best Russ @ MR
Moulder Pressure Shoe Calibration
4/23/21       #4: weinig end snipe ...
Mike M Member
Sounds like the feed system is trying to force the material away from the inside fence. This would be typical of a smaller older moulder.
