Solid Wood Machining
wideblade 5 " verticle or horizontal 1"throwaway
8/15/16
woodking
we are considering resawing 2x6 spf kd into deck boards for the pallet industry we have the ability to access an older cantek 36" band resaw with 5" blades. how long should they last compared to the throwaway 1" that baker uses on their horizontal bandsaws. once installed can a person with guide modification run a 1" on the verticle resaw? the cost of sending out the widebands to be serviced scares us.
8/15/16       #2: wideblade 5 " verticle or hori ...
Hen Bob Member
We run a 1" Lenox carbide tipped on a 36" saw.. not cheap but they last quite a long time.
8/15/16       #3: wideblade 5 " verticle or hori ...
tb
we have got about 4 to 6 hrs at 50 fpm on the bake resaws when you saw you have good results on the 36" how many hrs and what are you sawing. was the saw originally for a wide blade what modifications did you do just guides?
8/16/16       #4: wideblade 5 " verticle or hori ...
A Wadkin PBR resaw would run a 3-1/2" wide blade for about 2 weeks before changing due to dullness. Split about 5,000 l/f of Poplar per day at 30 l/f per minute. I don't recall the costs to sharpen, but we had a crate and loaded it and sent it to Menominee Saw Works. They returned it with sharp blades. While appearing at first expensive, they took good care of the blades and each one lasted for years.
