Solid Wood Machining
Shaper cutter for 5/16" bead
8/17/16
Willie
Website: http://smithwoodinc.com
Does anyone know where I can get a 3/4" bore shaper cutter with a 5/16" bead? I can find 1/4" and 3/8" beads all day long, and I can find a router bit with 5/16" bead, but I was hoping to find a shaper cutter because I have a lot of trim to make and it really needs to have 5/16" bead.
8/17/16       #2: Shaper cutter for 5/16" bead ...
Pete D Member
These aren't the best, but they stock them. Believe it's the right size...
https://www.magnate.net/mobile/Product.aspx?ProductCode=M011
Could also get a knife cut for corrugated head if you've got one. Wouldn't cost much & cut quality would probably be better.
8/17/16       #3: Shaper cutter for 5/16" bead ...
door shop guy
Add a power feeder on your router table and get the router bit. I love having a power feed on my router table and woud not be without it. Just a suggestion.
8/19/16       #4: Shaper cutter for 5/16" bead ...
Russ
Website: http://www.mr-moulding-knives.com
Willie
I can make you a 5/16" thick corrugated high speed steel moulding knives for your shaper with any size bead you want. Lead time is about 24 hours, contact information is on my website if I can be of any help.
Have a nice weekend.
Russ
8/19/16       #5: Shaper cutter for 5/16" bead ...
Willie
Thanks Pete D and Russ. I'll probably buy the Magnate cutter for now because it's only $50 and it's in stock.
Thanks for the link, Russ. I'll definitely keep your company in mind.
