Solid Wood Machining
SCMI basic 1 edgebander not running correctly
8/25/16
Tim Member
Website: http://sdikitchenandbath.com
I'm hooking up a SCMI basic 1 edgebander that I just bought. It turns on, thermostat turns on and glue pot heats up to desired temp (220) and then shuts off. That's all good, but nothing happens past that. I'm told the white button should light up after the glue pot is heated and I should press that and then start switching on the belt etc. I am 99% sure this machine is in working order and I'm just being an idiot but I need someone to point out my mistake here. Thanks for any help!
8/31/16       #2: SCMI basic 1 edgebander not running ...
JimHerron
Wired correctly?
Tried swapping two of the hots?
Track belt running correct direction?
