Solid Wood Machining
Makita 2012NB Adjust Plate
9/7/16
Woodworker Member
There are adjust plate for Makita planers 1804N, 1805N, 1806B. But i Found my makita 2012NB is not provided with the adjust plate. If that so, why they are selling Makita HSS plate that need adjust plate?? May I know where to buy adjust plate for Makita 2012NB..
Ty
9/7/16       #2: Makita 2012NB Adjust Plate ...
Woodworker Member
I was told about the adjust plate by Makita, Part number 762016-0. I wander why Makita told me there is no need to use set plate for makita 2012NB after using adjust plate...lol.. will the blade flies like ninja blade?
9/26/16       #3: Makita 2012NB Adjust Plate ...
woodworker
no more adjust plate for 2012NB. you need to order special set plate and screws from Japan if you are using resharpenable knife on 2012NB. They don't come with machines and many suppliers do not know about that.
10/24/16       #4: Makita 2012NB Adjust Plate ...
Woodworker
Bought from Japan, and it is 2 in 1 plate which combines adjust plate on set plate. Very thin and looks unreliable. The set plate for disposable blade bend after 10 hours use. Too thin, and much thinner than the old 1804N or 1805N set plate.
