Solid Wood Machining
Molding knife compatibility
9/28/16
Chris M
Has anyone had any success using Williams and hussey molding knives in a Woodmaster machine? I've called Woodmaster and did not get that great of an answer. The mounting holes in the hussey knives apparently create a loud whistle due to the amplification.
10/1/16       #2: Molding knife compatibility ...
Russ
Website: http://www.mr-moulding-knives.com
Chris
On a Williams and Hussey or Shop Fox moulder the target dimension from the bottom of the knife to the deepest part of the profile should be 1.500" - 1.593".
I don't manufacture knives for the Woodmaster but I believe there target dimension is somewhere around .812" - .875" this may be the reason you did not receive such a favorable response.
Safety first, it keeps you in favorable health.
Good Luck
Russ
