Solid Wood Machining
Scissor lift source
10/14/16
David Waldmann  Member
Website: vermonthardwoods.com
Any recommendations on a source for scissor lifts? This is the type used to raise/lower packs of lumber to reduce bending at infeed/outfeed of machine. +/- 4000# capacity (full packs will weigh more than that, but when a full pack is on it, it will be in the fully down position for a while). 30-36" x 60-72" table (we will bolt/weld I-Beam "bunks" on it.
10/14/16       #3: Scissor lift source ...
B
I just started to look at these myself. I found an electric automotive scissor lift rated to 6000lbs with 7 locking positions at www.titanlift.com
Not sure if this would work or not.
10/14/16       #4: Scissor lift source ...
B
Forgot to mention that the price was around $1500 usd through a local dealer.
10/18/16       #5: Scissor lift source ...
Have you looked at industrial recovery services or bid spotter?
There are many on the used market.
10/18/16       #6: Scissor lift source ...
Craig Caughlan Member
Website: http://www.wetimber.mx
I second the suggestion to buy used; Google 'scissor lifts used/auction'.
Suerte!
