Solid Wood Machining
Tool grinder
2/8/17
We try and buy our moulding but I feel a Moulder may be in our future so we can control timing and quality.
We have a US Concepts arch moulder with the straight moulding accessories and a W&H moulder.
We have heads and make crown in odd species and other moulding now. We also run multiple profiles on changers. The problem we would run into is a nicked knife and lines in the moulding that take time to sand out.
I am considering getting a grinder so we can grind/sharpen our own tools. I realize the math does not work on this and buying multiple knifes makes more sense in the short run but I like control and we will likely get a moulder in the future and this will put us one step ahead.
What is needed to grind quality knifes?
What brand of grinder and support equipment should I look at?
New or used?
Where can we get training?
What question should I ask that I have not?
2/8/17       #2: Tool grinder ...
I would need to be able to grind corrugated shaper tooling 4" diameter and 1-1/4 bore.
2/8/17       #3: Tool grinder ...
Dr. David Rankin
In order to make in house tools you will need:
Cutoff saw to cut the steel
Balance scales (I use an O'Haus Scout) to balance the knives
I use a bench grinder or tool grinder to square the knives
Method to make or buy templates(many people purchase CNC templates from many sources
Profile Grinder to meet your needs
You can get into a good profile grinder from about $4500 up or so
Sometimes you can find a good deal for less.
Be aware of the major wear points such as bearings, adjustment rods and nuts, back clearance castings, etc.
While using the profile grinder you will need
grinding wheels
coolant
dressing diamond
hones and cleaning tools for the knives after they are ground
I general tell people that it will cost between $6500 and $25,000 to set up a good tool room for a small to medium shop. This range depends upon specific needs of each shop.
If you find a small moulder, you need to allow for dust extraction hookup, electrical hook up, pneumatic hook up and rigging.
Be Safe,
Dr. David Rankin
2/9/17       #4: Tool grinder ...
Chuck Hicks
Website: http://www.southeasttoool.com
Here is a great web site to start on.
https://www.weinigusa.com/us/
Be careful when buying used machines, Like Dave said, check them out carefully.
