Solid Wood Machining
Recent six head moulder purchase
2/19/17
Mark Member
I recently purchased a Wadkin six head moulder with two right side heads and only one top head. It didn't come with any tooling, so I am asking your advice how you would set up this machine. I am mainly looking to do T&G paneling to start. I'd appreciate any help in pointing me in the right direction.
2/20/17       #2: Recent six head moulder purchase ...
rob
The short answer is you will generally put a straight tool on the first right and mould with the second.
The correct advice is to hire or find someone who knows what they are doing to train you how to use it.
2/22/17       #3: Recent six head moulder purchase ...
Dr. David Rankin
When I run a moulder with 2 rights heads I use two different methods of running T&G. If I am running a variety of profiles, I will run a straight knife on the first right head and the profile on the second. If I am only running T&G, I will run the profile on the first right head without the groove and the groove on the second right head. This way I can use a grooving disk that will last longer and help maintain a more precise part. If I am running carbide inserts or a stackable head then I will run it on the second right with the straight head on the first right.
In other words, there are a couple of different options depending upon your production requirements.
Be Safe,
Dr. David Rankin
2/22/17       #4: Recent six head moulder purchase ...
Mark Member
Thank you both for your response.
My next question, the second right head has the height adjustment in the back of the machine is that common? The first right head has both height and width controls in the front.
2/22/17       #5: Recent six head moulder purchase ...
rob
Seems unusual to me, especially on the 2nd, but I am a Weinig guy. Dave would be more familiar with the Wadkins. Here is an excellent tooling solution if you are doing a fair amount of various tongue and grooves. http://www.glct.com/sg.html
Rick Earp at Weinig USA can provide you with more info on them if you are interested. Again, you would do well to get a technician out to go through the machine and provide training, or at a bare minimum attend a class somewhere.
Good Luck.
Rob
