Solid Wood Machining
double end tenoner work
3/24/17
Gary
I need to sub out 1500 pieces to someone with a double end tenoner. Any takers?
3/25/17       #2: double end tenoner work ...
That is it? Do you have tooling?
3/27/17       #3: double end tenoner work ...
I meant to say what is it?
3/27/17       #4: double end tenoner work ...
Gary
Simple parts all the same. About 14" long, 2" wide, 3/4" thick with a 3/8" x 3/4" rabbet at both ends. Exact dimentions not known at this time. Red oak.
4/25/17       #5: double end tenoner work ...
Woodworker Member
If it is the simplest type of tenon, then screw ur 3hp plunge router (with white-side router bit) under table, with a guide and own t-track, a day may able produce 500 double end tenon.. per person. Try it.
Sharpen ur router bit with angle grinder with diamond disc first..
4/25/17       #6: double end tenoner work ...
Gary
Got it done in house with a shaper. Went faster than I thought it would. As it turned out we didn't have time to sub it out.
