Solid Wood Machining
Kentwood / Leadermac Moulders
4/4/17
I am looking for people that have had experience with Kentwood or Leadermac moulders. We are considering a moulder and looking at all the options.
I believe the way this works is if you have something "not so positive" to say you will have to email me or this thread will be removed.
4/4/17       #2: Kentwood / Leadermac Moulders ...
Russ
Website: http://www.mr-moulding-knives.com
I have many clients that use all the major brand names.
All companies have both, positive and negative things to say about each brand of moulder out there.
The best advice I could give you is to talk to the technicians and operators of any of the machinery. Every salesmans job is to convince you their moulder is better than the other guys.
Receive quotes from all the brands you are considering and even those you are not considering. Most of all do you homework, if there are things you dont understand, ask questions until you do understand.
If I can be of any help, please feel free to contact me, information is on the site listed above.
Good luck to you in your new purchase.
Russ @ MR
5/2/17       #3: Kentwood / Leadermac Moulders ...
Steve
We ran a 2002 Weinig Unimat 23E for about ten years, we bought it used. We had no problems with this machine other than the occasional feed issue. The only thing we ever did to that machine was put a set of belts on it. That being said, we just purchased a new Kentwood M609. We went with the Kentwood based on more bang for our buck. We also have a dealer and a service tech that is pretty close to us. So far we love the Moulder and have no regrets.
6/1/17       #4: Kentwood / Leadermac Moulders ...
Jason
I run a Kentwood 612HD and we compared Kentwood to Leadermac. I agree more bang for the buck but I also run a Weinig and just everything about the Weinig is machined more precisely. i.e. You can loosen a fence to adjust it forward/backward without causing a bunch of of side to side slop just because it was loosened.
With that said the Kentwood does a great job and we are happy with it.
