Solid Wood Machining
Scalloped drawer fronts
4/18/17
CBWW
Website: http://cherrybrookwoodworks.com
Looking for some feed back on fabricating the drawer fronts in this image. I do not have a CNC... My thought is to build the drawer fronts as vertical staves, profiled to the cove, splined for alignment, and then basically cooper the drawer fronts. But, if I have drawers on extension glides with a flat front, the issue arises on how to attach the curved front to the flat drawer box. I also have the issue of expansion with vertical staves but the piece is minimal in total length(55" or so). Any thoughts?
View higher quality, full size image (639 X 482)
4/18/17       #2: Scalloped drawer fronts ...
55" can add up. The strategy would be to use quarter sawn stock for the vertical drawers fronts. If you are using slides, the side clearances will have to be 3-6 times (.060" to .125") what they would be if the drawers slid in web frames, so you have some room for expansion.
I would not use the scalloped fronts as then attached to another drawer (box) front. Make a french or traditional dovetail and a groove for the bottom and let the scalloped front be the drawer front. No need for redundancy.
4/18/17       #3: Scalloped drawer fronts ...
Forgot the picture....
This is drawer with a single front french dovetailed to the sides. It goes into the cabinet with a radius front. The over length sides help prevent pulling out the drawer too much. They are also dovetailed to the backs.
4/18/17       #4: Scalloped drawer fronts ...
CBWW
Thanks David. The 55" is the total length of the piece so the drawer fronts would only be around 18" wide give or take.... Personally, I'm not sure how that front would look with the scalloping at that dimension. I have not had a discussion with the decorator over this as of yet. I thought about the French dovetail after I posted here. Your input is appreciated.
4/18/17       #5: Scalloped drawer fronts ...
I'd have a custom router bit made and rout the scallops using a custom jig to change the angle of the router. Maybe one of the Magnate bits will work.
Magnate bits
6/8/17       #6: Scalloped drawer fronts ...
joe Member
I have a 5 axis cnc and could make these as I have made them before.
Send me a rough sketch with materials and I'd be willing to send you a price.
