Solid Wood Machining
moulding none ripped material
4/21/17
Jeff Traeder
My company has this idea to buy material that is cut from bolts and resawn to width and then dried. The first batch showed up and it varies in width by 3/4"! they want me to run this as is through to moulder as is. any thoughts!
4/21/17       #2: moulding none ripped material ...
Russ
Website: http://www.mr-moulding-knives.com
Jeff
I think this could cause damage to the machinery.
You will have to find a happy medium for the infeed fence, whatever lumber is leftover will be milled by the left cutter head.
The problem lies with the chipbreaker in front of the left cutter head, it only has so much receding movement, this is the area where damage could happen from too wide boards. If the lumber misses the chipbreaker, then chatter is imminent.
Tough task
Good Luck
Russ @ MR
