Solid Wood Machining
CNC laser cutter for solid wood?
4/9/17
JR Rutter
We are looking at doing some precision cutting with square inside corners and have seen some samples done with a laser that look good. Anyone here have experience with a laser cutter capable of through cutting 3/4" + stock?
4/14/17       #2: CNC laser cutter for solid wood? ...
Not even close. I have a small wattage ULS machine. I've never seen a quality cut with a CO 2 laser in any thickness of wood, it's always charred. What kind of laser did you get the sample cut with? I'd also check how square the cut is to the surface. Laser beams are tapered, and depending on focal point, the cut would be tapered in that thick of material.
4/14/17       #3: CNC laser cutter for solid wood? ...
JR Rutter Member
Website: http://harmonicdesignworks.com
Thanks. I will check for taper, but looking at how the parts fit together I didn't see anything unusual. The edge charring is not a concern, and may even be a design element.
4/14/17       #4: CNC laser cutter for solid wood? ...
Don't you think the char is going to be an issue with gluing? Is it done with a CO2 laser? Did they tell you how many passes and what speed?
4/25/17       #5: CNC laser cutter for solid wood? ...
Woodworker Member
I wander those solid woods with burning oils inside may burn ... even the stock get burnt during planning process..
5/18/18       #6: CNC laser cutter for solid wood? ...
Cherry Stylecnc Member
Website: http://stylecnc.com
Pls tell me what's the max thickness about the wood you want to cut? there are so many watt laser machine for options.
View larger image
100W CO2 Laser Wood Cutter for sale
