Solid Wood Machining
Raimen saw programming?
4/26/17
James Member
Hello all!
I'm wondering if anyone can tell me if there is any way to create a separate program for the proper rip size for every profile that we run at our shop, or if there is a way to just bring up a generic screen that allows you to simply and quickly enter the rip size and footage needed? I'm thinking along the lines of the Powercom software where you would just type in the profile number and the program would pop up.
I recently started work at a shop that makes raised panel doors and mouldings. I've been running moulders for over 15 years, but we used a Mereen Johnson at the last shop so I'm not familiar with the Raiman software. The Raiman is linked to the office and is sent a rough mill cut list every morning for all the parts needed for the day for the door shop. What I'd like to be able to do is be able to just quickly call up a profile when I need to cut moulding orders rather than having to create a new work order every time. Any help is much appreciated!!
James
4/27/17       #2: Raimen saw programming? ...
jl
Not sure how your connected to the front office but we can set up cut list that are saved on the local computer, we have lots of them for parts we produce. Of course anything new has to be created but can easily be saved and named whatever you like. You'll still have to go into the cutlist folder and navigate to it but that fairly easy.
4/27/17       #3: Raimen saw programming? ...
Troy
I run a Raimann KR610 with VR4. Tap Raimann square bottom right on screen, tap orders, tap create new order, that should open up all the order files in the system. Open up one to modify it or tap on the right side of "orders" to create a new one. You'll have to at that point give it a name, lumber thickness, couple other pieces of info if you want to track what you cut in that order. We got about 20 different orders we tweek cut lists on as needed and I keep two orders labeled "misc" that only have a couple sizes in where I can quickly add and delete sizes if we need to cut one board or two. When you enter a size you'll need to tap the folder close and tap again to open it to refresh it, your size will then show up. Tap on the right side of the size to give it a "value". It will default to 100% but I've found when there are many sizes to cut you'll want to start at 100,110,120,130% and so on, you get the idea. Under where you give the size a value you can enter a quantity, say if you only want 1000' of one part. If your after unlimited quantity just leave the limit a "0" and it will cut forever. Word of caution, if you have a fixed pocket on the ardor it must be in the cut list weather you use it or not, if you don't want too just tweak the value to "0" and it turns it off but it must be in the order. All other sizes can be turned on or off in the value screen as needed. It doesn't take long to learn it and getting a handful of sizes programmed in can be done in less than a minute.
