Solid Wood Machining
CNC/Digital crosscut fence for tenoner
7/21/17
Bob Holloway Member
Website: advantagewoodwork.com
Hello All,
We have an older SAC T3 tenoning machine with the old style bubble indicator for length stop. We need a more accurate repeatable stop system for greater accuracy and repeatability. We are looking for advice to retrofit or improve our current setup or purchase a new device. Currently our stop can measure up to 3,500mm long, it has removable sections for different part lengths so you are not always dealing with that long fence. Ideal a stop system from a sliding table saw with the extendable outrigger type cross cut stop would be nice.
7/21/17       #2: CNC/Digital crosscut fence for teno ...
Have you considered this?
Digital fence.
7/23/17       #3: CNC/Digital crosscut fence for teno ...
Joe Member
Hi Bob, Have you considered cutting to length before tenoning and using a tenon stop to set depth of cut for the tenons? I have my shaper set up to cut tenons this way as there is no cutoff saw like on your tenoner. I recently obtained parts from Igus to make a tenon stop with counter and position lock that is working nicely and can be set to .1mm. I have referenced zero to the center of the spindle and written the most used stop positions on the top of the tenon stop. I think setting up a DRO on a multi section fence will be expensive and difficult to use considering that the fence can be disassembled. The next step in my plan is to add an automated stop to my Northfield Unipoint saw to cut scantlings to length. Currently I am using my sliding table saw with manual stops to cut to length.
I can send you a list of Igus parts I used for the stop if you are interested?
Joe
8/5/17       #4: CNC/Digital crosscut fence for teno ...
Hans Member
Website: http://www.baide-cnc.com
www.baide-cnc.com
