Solid Wood Machining
Edge Chipout
10/1/17
Stewart Member
Okay, so I am usually only cutting up plywood on the cnc router. I've had some solid wood (hard maple) arched valences to cut on this project. I figured it would be no problem but I am getting a lot of chip out on the edges. I'm using a 1/4" comp bit taking several passes (18000 rpm and 300 ipm) and conventional cut direction. What do I need to change? Thanks for your help!
10/1/17       #2: Edge Chipout ...
I use a roughing bit and cut about 0.020 oversize first. Then the comp spiral.
You may have to experiment whether conventional or climb works best since the grain changes 1/2 way through the arch.
Maybe just the roughing bit and sand smooth.
10/1/17       #3: Edge Chipout ...
Stewart Member
Thanks, Dropout! What kind of roughing bit do you use?
10/1/17       #4: Edge Chipout ...
3/8 3 flute slow up cut. Minimum 800 ipm @ 16K rpm.
10/1/17       #5: Edge Chipout ...
I use the same bit as a first cut for ply. Keeps from breaking comp spirals on import material.
10/2/17       #6: Edge Chipout ...
Stewart Member
Thanks, Dropout! This is helpful! One more question - do you use climb cut for solids?
10/2/17       #7: Edge Chipout ...
Make sure the first cut is deep enough so you hit the downshear portion of the compression bit or your first pass is effectively cutting with an upshear bit.
10/2/17       #8: Edge Chipout ...
Climb with the rougher.
Whatever works best for the rest. Trial and error.
10/2/17       #9: Edge Chipout ...
Stewart Member
Thanks, guys! Much appreciated!
