Solid Wood Machining
Sunhill shaper
3/8/18
sean Member
Website: http://arcmdm.com
we acquired an old sunhill shaper (champ Fond) model # sp -106s. It only has the router collet , & no spindles. Anyone have an idea on where to purchase a spindle, 3/4", or 1 1/4" . I hate to scrap it, we just had it basically donated to our shop, & would like to put it in production.
Thanks,
Sean
3/9/18       #2: Sunhill shaper ...
Ken Member
If you have a removable router collet post a pic some we can see the taper. You may be surprised that it might match a HD or LD Rockwell or a Powermatic 26 or 27.
3/10/18       #3: Sunhill shaper ...
sean Member
Ken,
I have both shapers you mentioned already checked spindles on most machines I could think would match, no luck.
3/10/18       #4: Sunhill shaper ...
Ken Member
Sean, remember Delta changed the spindle tapers on their HDs sometime in the '80s, I think it was around the "Platinum" series. The early tapers were a short 60 degree taper. The later ones were significantly different, a much longer taper. Also, look at the cartridge size, might be able to stick a PM or Rockwell cartridge in there with little or no modification. Post a pic of the tapered router spindle if you get a chance.
3/13/18       #5: Sunhill shaper ...
Matt Calnen
I know that 90’s era powermatic and Grizzly spindles are interchangeable.
3/22/18       #6: Sunhill shaper ...
Jared Emery
Sean I have the same shaper, and I have a 1" spindle for it that I don't use. Let me know if you still need something to get it going.
3/22/18       #7: Sunhill shaper ...
Ken Member
Hey Jared, if you have a sec would you post a picture of that spindle? I'm interested in the taper.
3/23/18       #8: Sunhill shaper ...
Jared Emery
This is a 1" spindle. I didn't clean it up. Bottom diameter at the tip of the taper is a smidge less than 1"
3/23/18       #9: Sunhill shaper ...
Sean Member
Thanks for all the replies, I have located 2 spindles. Jared if the 2 I've located do not work I will be in touch.
Thanks,
sean
